Hi guys,
I am new on the forum. Sorry for mailing in english. I do understand the german language very well but writing without grammatical errors is too difficult...
I do live in north-west flemish speaking part of Belgium, for those interested in history: noth that far from the first world war battlefields.
Due to some health problems I could not ride my motorcycles anymore and therefore I recently bought a 2008 Honda Innova 125I with windsccreen with only 250 km for the total of 1000 euro.
The bike was very dusty but after cleaning appeared to be almost brand new. And there was a very nice Sebring exhaust too.
Now with only 1250 km there is a problem. I can not start anymore with the electric starter. When put the ignition on, the dashboard lights functions and I can hear the fuel pump working. When I push the start button, nothing happens and the starter engine remains completely quite, not even a "click".
With the bike in neutral, I can kickstart the engine immediately which complete turns normal and sounds very well. So far so good, but when I then put the engine in first gear, the engine stops turning.
I could not find any fault and also cheched the sidestandconnection. But to be honest: I a fairly bad in electrics...
Is there somebody on the forum who can help me or can give me some advise? You may answer me in german.
Thanks.
Greetings
Dirk
Alasser - starter engine
- Fritten-Robert
Re: Alasser - starter engine
Hi Dirk (wie kommst Du zu dem Vornamen?),glodi hat geschrieben:Hi guys,
Thanks.
Greetings
Dirk
willkommen hier im Forum und herzlichen Glückwunsch zur "neuen" Maschine.
Aus der Ferne würde ich auch auf das Seitenständerproblem tippen. Am Seitenständer ist ja dieser Schalter dran. Check den mal, ziehe den Stecker ab. Dort dürften 2 Strippen/Kabel hingehen. Schließe die kurz. Jetzt dürfte die Innova wieder laufen. Besorge Dir aber besser bei Gelegenheit einen neuen Schalter, bevor Du irgendwann mit herausgeklapptem Seitenständer losfährst und in der nächsten besten Linkskurve abgehst.
Mach und berichte.
Robert
Many thanks Robert for the fast reply.
Well my first name is in the northern part of Belgium (Flanders or in German "Flandern") common for people of my age (50 plus...) The Flamish language is one of the Germanic languages (Niederfraenkisch-Wikipedia) and some German first names are very usual (euh, were very usual before the "damned Americanisation" of our language).
Belgium is not a French speaking country as many people think: more than 55 % speak Flemish but my region knew in the past a very strong influence of French, hence my familyname.
Tomorow I will try your advice and check the sidestand again.
To be continued...
Greetings,
Dirk
To be continued...
Greetings,
Dirk
- CB50_1980
- Fahrzeuge: ANF 125i
Moin Dirk,
und ein herzliches Willkommen nach Flandern. Zum Starter-Problem scheinen mir wie Robert der Seitenständer-Sensor und seine Kabel die Hauptverdächtigen zu sein. Die sollen schließlich den Motor ausstellen, sobald ein Gang eingelegt wird. Hier mal Bilderchen vom Seitenständer und vom Kabelbaum. Vielleicht ist ja einfach nur eines der kleinen Kabelchen locker. Viel Erfolg!
Hallo Dirk,
als je er met engels of duits niet meer uitkomt, kun je mij ook zo vragen.
Groet,
Gert Q.
Groet,
Gert Q.
Gert,
bedankt voor het vriendelijke voorstel.
Met Engels heb ik geen probleem bij het lezen en schrijven (alhoewel ik heb moeten vaststellen dat ik toch enige fouten over het hoofd zag) maar Duits schrijven is een ander paar mouwen...
Uit pure nieuwsgierigheid: Ben jij Duitser of Nederlander?
Ik ga deze namiddag eens aan de arbeid en proberen het elektisch euvel op te lossen. Op hoop van zegen.
Groeten,
Dirk
Groeten,
Dirk
Hi Martin and Robert,
yesterday I checked the sidestandswitch. It was defect. I did as you told (disconnecting the switch and coupling the two tiny cables) and the Innova is now back on the road.
Thanks again for the tip.
Dirk
Dirk
- Fritten-Robert
Hi Dirk,glodi hat geschrieben:Hi Martin and Robert,
Dirk
Alstublieft. Dont forget to replace the switch.
Robert
Hallo Dirk,glodi hat geschrieben:Gert,
Groeten,
Dirk
Nederlander met meer dan 20 jaar levenservaring in Germania :zwinker:
Groet,
Gert
